reg93f150 Posted October 16, 2012 Report Posted October 16, 2012 Okay so I just picked up some nice aluminum wheels from one of my. Buddies for basically free.. they're just dirty as shit on the inside and cloudy on the outside of the wheels, I was thinking just sand them down with like 200 grit then move up to 500 or so, then alum brightener, polish. What do yall think/recommend? Thanks ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
josueh95 Posted October 16, 2012 Report Posted October 16, 2012 200 grit? no that would be too rough on the rim and make very hard scratches. i wetsanded my aluminum rims. start out with 600 grit and go to 800 then 1000 and 2000 then just add an aluminum polish to it and it should look great -2000 chevy tahoe 5.3 liter v8 -two DC audio level 3 15 inch subwoofers -2 pairs of infinity kappa 60.9cs components -rockford fosgate t1500.1bd for subs -rockford fosgate t400.4bd for mids and highs -alpine deck -big 3 upgrade 0 gauge power cable -optima yellow top battery -custom made subwoofer enclosure 6 cubic feet tuned at 35hz
Redremedy Posted October 16, 2012 Report Posted October 16, 2012 Wish I still had a picture of the whole wheel done, but as josueh said wet-sanding works well. I mainly used 2k grit, and 1k grit in the corners I couldn't really get into. I used the water from my car wash bucket(wasn't really dirty water), was VERY mildly soapy(like if you mixed the water up you would get a bubble ring but nothing major). You will want to keep your paper wet, so as you go keep dipping it in your water. I didn't have to apply a lot of pressure when doing mine, so start light and apply more pressure if you need to. Then a coat of metal polish(I used mothers), then a coat of wax. Took about a week off and on to do all four by hand, they came out pretty nice. This was the first set of wheels I have done, so I am not claiming to be an expert. I am only sharing my experience with the subject. The picture doesn't really show just how shiny they are(and I don't have them anymore), but they cleaned up well and looked really good in the sun. All in all, I would say it was pretty easy process. @ reg - Do you have a picture of said wheels?
reg93f150 Posted October 16, 2012 Author Report Posted October 16, 2012 Thank yall for the help, and I do not have a picture of the wheels right now, but I can for sure get one later after school just to show y'all ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
