most watts from 50 amp fuse
The amp is not drawing current over the 50 amps its fused at. So teh question is why not. Are you sure the speaker load being presented to the amp is 1ohm or are you just going off what you were told?
I ran a Fosgate 250x2 off a 60amp fuse full tilt with a 4 ohm load(one 15" solo baric) and never had an issue.
And to add to the mix, I had 3 amps running off a 100amp main fuse. 2 Fosgate 60x2's and that 250x2. The 60's had 30 amp fuses to each and the 250x2 had the 60 amp fuse.
Rolex you sicken me.
Just let me finish my pie
~ Juice
Tested with DDM each sub is at 2.3 ohms then brigded at amp is this correct
It's a mono amp so you can't bridge it.
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
if you're not wired exactly like this (all +'s together, and all -'s together) then you wired it wrong.
If it's wired like this it'll be at 1 ohm.
2003 corvette z06
Basic DC electrical mathematics:
Amps x Volts = Watts > 50 x 14.4v (optimal) = 720w
So if your amp draws more current (provided its availabe without dropping the voltage) a 50 amp fuse will blow beyond 720 watts, in theory*
Same thing but backwars to figure how big of a fuse to allow 1500 watts
Watts / Volts = Amps > 1500w / 14.4v = 105a...again in theroy*
*none of that includes calculating efeciency, impedace rise and all the other fun stuff that affects amplifyer output
200a fuses are your best bet. And of course, what others are saying is true, get bigger power wire.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
  • Who's Online   0 Members, 0 Anonymous, 2496 Guests (See full list)
