dpeebs Posted November 11, 2012 Author Report Posted November 11, 2012 i dont have a voltmeter, i do have a dmm but i had it all tested. ill check it all again, monday im gunna get my battery check under load aswell but it does explain the strobing lights and the battery on with out the truck running i have no problems
dpeebs Posted March 5, 2013 Author Report Posted March 5, 2013 okay so thought it would let you guys know i fixed the problem. i know this is an old post but for you guys having the same problem it was the little wire comming off the alt harness to the regulator that had a broken clip inside so it wasnt making a connection. this was causing my amp to go into protect. fixed it not a problem since. thanks guys for your help and input
