dpeebs Posted October 22, 2012 Report Posted October 22, 2012 i started my truck today after sitting all night and now all of a sudden my voltage with no music on goes up and down, when i accelerate it dooes the same thing my gauge moves up and down and the lights kinda dim out as the voltage moves, i have just the stock alternator in there which is 95a and im running a hifonics brz 1700d and a kicker zx350.4 i have a 230a alternator just havent put it in yet. also i have done the big 3 upgrade, and if i need to change out the alternator do i need to upgrade any other wires or am i good to just plug it in, my vehicle is a 1991 ford explorer 4x4 4.0L automatic. please help would like to fix tonight
Guest Posted October 22, 2012 Report Posted October 22, 2012 make sure all connections are tight. if you have the new alt already, just put it in. only thing you need to do with it is the big 3 in 0 gauge.
dpeebs Posted October 22, 2012 Author Report Posted October 22, 2012 okay, thanks ill check connections first, i dont want to change it tonight because its already dark. also my big 3 is 0 gauge and can i ground to my alternator braced that mounts to the block? i have it to the factory ground and i was told thats not good to have 2 grounds there.
Guest Posted October 22, 2012 Report Posted October 22, 2012 its perfectly fine if you put the ground on one of the holes that the alt mounts onto. its preferred last i checked.
dpeebs Posted October 23, 2012 Author Report Posted October 23, 2012 okay i took the old alternator out and put the new one in and it does the same thing at idle but at 1500 rpm is goes away. is it maybe my battery or would it be the lack of amps running things?
dpeebs Posted October 27, 2012 Author Report Posted October 27, 2012 i put my 230 amp alternator in on monday and last night (friday) i got in my truck and it did the same thing and my amps turn off when it does this, well my 4 channel cuts out. i found a video on youtube that is kinda the same problem im having but mines constant all my connections are tight could it be that the ground on my block is no good? because its the factory ground it has like a 8 gauge wire so i justed added a 0 gauge to it and my alternator has a threaded hole in the top i want to ground to that but want to see if anyone can help me out first before i rip apart my truck
DRCinc Posted October 27, 2012 Report Posted October 27, 2012 make sure nothing is corroded and they are all nice and tight. start wit that
dpeebs Posted October 27, 2012 Author Report Posted October 27, 2012 okay is there anything else it can be i cant do much right now im at work and its dark outside. im gunna get new terminals tomorrow and check all soder connections and ake sure everything it tight
Tarball Posted October 28, 2012 Report Posted October 28, 2012 I'm not familiar with ford charging systems but you seem to be getting voltage spikes. Is your voltage regulator built into the alt or external? CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
