Subs not playing correctly.
dl9890
Please tell us how you have your subs wired.
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
a non centered port can cause loading issues for the woofer that is closer to the port. things along the lines of the sub that is closer to the port moves more, or it bottoms out easier.
so you do have a L shaped box? like (port, Sub, Sub)
I have an L shaped port with the subs on the left (Facing up) port on the right (Facing out)
do you have pics of the setup?
sounds like a loading issue as stated earlier
I do have pictures, just don't know how to get them on here. Have them on photobucket, don't know which code to use.
They are wired at 1 ohm. Wired in parallel
Not trying to bash your knowledge but are you sure they're wired correctly? We all make mistakes man so if I was you I'd triple check my wiring and make sure I mix a positive and negative somewhere along the line.
Good luck!
(1) Mechman 240
TEAM NWSPL
155db outlaw
  • Who's Online   0 Members, 0 Anonymous, 749 Guests (See full list)
