adding a deep cell to standard battery, pro installer help me pls!
Hi, I am going to buy a kinetik for my trunk
I would like to have both batterys wired together for that extra power incase the kinetik needs it
(i dont have a capacitor nor do i believe in them)
I dont have a super powerful amplifier so im not pulling crazy power
My question is: if i have both batts wired together could this cause any damage to my amplifiers since theyre not the same? (voltage drops or whatever)
(i understand series & parallel)
Also do I have to use 1/0 gauge for safety?
because I have tons of 4gauge I would like 2 use 2 hook up the kinetik
Just out of curiosity if i were to ground the amp in the trunk to the frame should i put it with same ground as my amps are on?
(idk much about batts or making bad ground loops or anything for that matter)
thanks alot!
**actin bad like a kid at six flags**
i don't mean a certified pro installer just someone who is familiar with this kinda stuff *holds up help wanted sign*
From what I gather regular batteries charge at a different rate than agm batts IE kinetic and you could potentially blow up a battery.
I ran an optima yellow and a regular battery for a year with no issue so to each their own.
0 gauge carries more current than other wire sizes so I'd run 0 to keep the power up.
150.1 @ 38hz142.3 @ 20hz (windows down)Only 2 batteries
  • Who's Online   1 Member, 0 Anonymous, 457 Guests (See full list)
