Yates Posted October 29, 2012 Report Posted October 29, 2012 sorry Im still a bit of a noob when it comes to the technical part of box build but what does the orders mean like 4th order 5th order wanna get it sorted before I put these bad boys in the 18's next to a unknown 12" which is now in speaker heaven
Yates Posted October 29, 2012 Author Report Posted October 29, 2012 oh and any tips for a box heres the specs specs are here Subwoofer with a diameter of 460 mm and 5400 watts of max power. Specifications System Subwoofer Diameter (mm) 460 Peak power handling capacity 5400 watts Nominal power handling capacity 1800 watts Sensitivity 94 dB (2.83V/1m) Frequency response Hz 20 - 200 Hz Impedance 2 x 2 Ohm Cone material Carbon/fibreglass Installation depth 245.0 mm Installation Ø 420.0 mm Hole circle 452.0 mm Included Design cover Thiele/Small parameters Fres 37 Hz Qts 0.6 Qes 0.71 Qms 3.8 Vas 36.7 l Xmax + / - 15.0 Enclosure recommendation Bass reflex 60 litres Tunnel Ø 2x 10 cm Tunnel length 2x cm Im more worried about how many cubic foot I need its going in the back of a station wagon not the one in the garage its a Subaru Legacy Grandwagon 1996
Yates Posted October 29, 2012 Author Report Posted October 29, 2012 7 users are reading and still no love 8 9
suckerfreebass Posted October 29, 2012 Report Posted October 29, 2012 i can tell you 4th order is sealed enclosure inside a ported enclosure
Yates Posted October 29, 2012 Author Report Posted October 29, 2012 I was thinking round 6 cubic foot box port face to back or up or through the arm rest in the back that could be cool still not sure of the amp done the big 3 with 110 amp alt at the moment
suckerfreebass Posted October 29, 2012 Report Posted October 29, 2012 you design your box from what sub an how much power you will push it with without knowing amp or what sub you have or what car cant really help
Yates Posted October 29, 2012 Author Report Posted October 29, 2012 you design your box from what sub an how much power you will push it with without knowing amp or what sub you have or what car cant really help Car: Subaru Legacy Grandwagon 1996 Sub: Blaupunkt VPW 460 power: 1500w rms each Audio Pipe 3000d
