grounding front and rear batts
So ive been looking on the forums and from what i can tell, there are two ways you can wire a front and rear battery in parallel to get 12v.
You can either run + to + and -to - to the batteries
Or you can run + to + skip the - to - and ground both batteries to a good grounding point.
Im guessing the - to - to both batteries is best, but is it neccessary?
Im going to run a D3400 and an XP750 on a mechman 220a alt.
Amp is an AQ3500 powering 1 DC XL m2 10" at 1 ohm. I dont plan on dishing all 3500w to the sub.
So a bit of voltage drop wont hurt me.
As of right now i was gonna do 2 runs of + and do 2 grounds to the front and rear batt.
To sum it up, do i absolutly need to run another 2 runs of - from the front to the back for this to work?
Thanks for any input
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
4 DC XL's W/ PSI Recones
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
Mechman 220a Alternator
Thanks bro, exactly what i was lookin for
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
If you can't get the voltage from front to rear within a reasonable range after completing the big 3, you should consider going with an isolated ground at that point.
Though, If your grounds are clean and solid, it's usually not a problem.
  • Who's Online   1 Member, 0 Anonymous, 1661 Guests (See full list)
