So, the mustang is up for the winter. Went out and bought myself a 05 Impala to drive this winter. If you know the mustang, then you know I won't be rolling without any system in my cars. Stay tuned for the build on this new car!
Build In Progress!
2000 V6 Mustang
H/U - JVC KW-ADV64BT
8 - P3D212's / 14cu. ft. / 34hz
Front - T1675x2, PPS4-8x4, T1TSx4
Rear - T1675x2, T165x2
Sub Amps - T2500-1bdCPx2
Mids/Highs Amps - T600-4x2
3SIXTY.3 Signal Processor
51Ft. RF 1/0 Spool x 2
Excessive Amperage 300amp Alternator
VMAX CT2500 x 2
Optima Yellowtop
Got a nice little car, is the mustang just a summer toy?
Mustangs don't play nice in the winter here in Michigan. Stang only comes out in nice weather :)
Build In Progress!
2000 V6 Mustang
VMAX CT2500 x 2
Optima Yellowtop
Ahhh my cousins has a mach1 with it puttin 800+ hp to the ground it doesnt play nice in any weather. I refuse to get a stang cause most of em have tractions issues. Havin the manual trans ( only trans id get with a sports car) only makes it worse
Oh the joys of owning a GM 3800 :) Decided to break it down as soon as I got it and swap out upper and lower intake gaskets as well as the coolant elbows and the valve cover gaskets. So much fun.
Upper intake had a bit of oil in it
Lower intake off
This is why you don't use dexcool!
Valve Covers Off
Coolant Elbow leak
All put back together
Build In Progress!
2000 V6 Mustang
VMAX CT2500 x 2
Optima Yellowtop
