dcm4588 Posted November 11, 2012 Report Posted November 11, 2012 I'm looking to buy a matching speaker for the one I already have. Looking for a dual 1.4 ohm 12" DC XL m1 07 Ram quad cab - Pulled the rear seatsDC audio XL 18 m1, PSI reconed dual 1 ohm, triple leads, 4 layer stiff spider wired up to a 2 ohm load 4th order bandpass 2.5:1 ratio tuned @ 45hz AP3000.1DBig 3 done in 1/0Odyssey PC1700 up frontOdyssey PC1500 rearAlt in the near future..." In the end, the "what if's" of what could have happened are what hurt the most..."
dcm4588 Posted November 11, 2012 Author Report Posted November 11, 2012 Depends on the sub. If it needs a recone, not much. If you have one, name your price. I'm looking to make a deal. 07 Ram quad cab - Pulled the rear seatsDC audio XL 18 m1, PSI reconed dual 1 ohm, triple leads, 4 layer stiff spider wired up to a 2 ohm load 4th order bandpass 2.5:1 ratio tuned @ 45hz AP3000.1DBig 3 done in 1/0Odyssey PC1700 up frontOdyssey PC1500 rearAlt in the near future..." In the end, the "what if's" of what could have happened are what hurt the most..."
dcm4588 Posted November 11, 2012 Author Report Posted November 11, 2012 I can have psi do magic with it. What are you looking for on a price? 07 Ram quad cab - Pulled the rear seatsDC audio XL 18 m1, PSI reconed dual 1 ohm, triple leads, 4 layer stiff spider wired up to a 2 ohm load 4th order bandpass 2.5:1 ratio tuned @ 45hz AP3000.1DBig 3 done in 1/0Odyssey PC1700 up frontOdyssey PC1500 rearAlt in the near future..." In the end, the "what if's" of what could have happened are what hurt the most..."
dcm4588 Posted November 11, 2012 Author Report Posted November 11, 2012 Daily bump... 07 Ram quad cab - Pulled the rear seatsDC audio XL 18 m1, PSI reconed dual 1 ohm, triple leads, 4 layer stiff spider wired up to a 2 ohm load 4th order bandpass 2.5:1 ratio tuned @ 45hz AP3000.1DBig 3 done in 1/0Odyssey PC1700 up frontOdyssey PC1500 rearAlt in the near future..." In the end, the "what if's" of what could have happened are what hurt the most..."
dcm4588 Posted November 13, 2012 Author Report Posted November 13, 2012 Gotcha. Well after all this, a local guy in a club I'm a member of is selling his 4 Skarr VVX 15's for $110 each, so I'm buying 2 of them. After I build the box for those, I'll see what she meter's then and make a judgement call. But from what I've gathered, these DC subs are expensive. Even the older models... 07 Ram quad cab - Pulled the rear seatsDC audio XL 18 m1, PSI reconed dual 1 ohm, triple leads, 4 layer stiff spider wired up to a 2 ohm load 4th order bandpass 2.5:1 ratio tuned @ 45hz AP3000.1DBig 3 done in 1/0Odyssey PC1700 up frontOdyssey PC1500 rearAlt in the near future..." In the end, the "what if's" of what could have happened are what hurt the most..."
