You might want to try facing them all the same way and see how it sounds.
It's really loud right now, and I have about 1/4" of roof flex, but the box isn't tunned to daily listening frequencies
816-591-6592
www.kcrimshop.com
I can go about 10" or so deep, and I have to keep 2 of the sides 9". So what should the other sides be??
Or I can shorten up the lenght of the port, and go a little longer on the unidentified sides.
816-591-6592
www.kcrimshop.com
It may be loud but I was just saying with some normal and some inverted using shared airspace they usually get out of phase. They fight each other, so you have to reverse the polarity on the inverted subs. Inverted sub = inverted polarity
You may know this already but just thought I would throw that out there.
Tiny Problem, when I have the 6 subs wired like the top pic, the amp does not clip, but its not as loud as when I have it wired like the bottom pic. But when I have it wired like the bottom pic, the amp clips.
These subs are 4ohm each. How should I have it wired so that the amp sees 2 ohm?
Not Real loud, doesn't clip
Posted Image
Really loud, Does Clip
Posted Image
816-591-6592
www.kcrimshop.com
Thanks BigPimpin, but I wanna try to get as close to 4 or 2 ohm as possible. I hear my amp isn't 1 ohm stable....... But it is 2000 wrms @ both 4 & 2 ohm.
I might end up selling this one and going with more amps.
816-591-6592
www.kcrimshop.com
Are your subs dual or single voice coil? If your subs are single 4 ohm voice coil then think of each row of the three subs as on set and wire each set (3 subs) in parallel ( pos to pos and negative to negative) each parallel set will give you 1.33 ohms. Then you just wire the last negative on the first set to the last positive on the second set. You will only have two free terminals left which will be the the positive terminal on the first set and the negative on the second, these you will connect to your amplifier giving you a final ohm load of 2.66 theoretically. Which is right about where you what to be. I can post a diagram if need be as my post may seem confusing.
4- COMP VR 15's
2- Tang Band 8's
2- Selenium 6"
2- Selenium Tweets
2- SAX 100.4's
1- SAZ 3000D
1- KQ9
1- KX3
Hopefully it doesn't sound too horrible. lol
Well, they're Dual 2 ohm voice coil. Would you please draw up a diagram? It took me like 5 minutes in paint
EIDT: Thanks for helping man
816-591-6592
www.kcrimshop.com
