westsideboiii Posted January 23, 2008 Report Share Posted January 23, 2008 Hello, I got an amp here. 4 Ohm rated. Is it possible to downgrade the amplifier to 2 Ohm? How? regards 1 Alpine 9886 1 Clarion APA250 100w @ 4 Ohms 1 Rockford-Fosgate 10" p2 1 Bassworx 10" Sealed enclosoure Link to comment Share on other sites More sharing options...
duct_tape123 Posted January 23, 2008 Report Share Posted January 23, 2008 What brand amp is it? Usually if its 4 ohm rated you shouldn't try to drop below 4 ohms. You can't "downgrade" an amp to 2 ohms, it would have to be to 8 ohms. As the ohms go down the amp produces more power, which causes unstability in some amps, which is why you should run your amp the way it is supposed to be run(4 ohms). Link to comment Share on other sites More sharing options...
westsideboiii Posted January 23, 2008 Author Report Share Posted January 23, 2008 Some information about the amp: Yamaha YPA-300 Amplifier 35 W x 2 or 80 W x 1 @ 0.1% THD, 20 Hz - 20 kHz Continuous Power Output (per channel, 4 ohms, 2 channels driven.) with 0.1 % THD, 20 Hz ~ 20kHz .................35W/35W with 0.1 % THD, 1 kHz .........................40W/40W (per channel, 4 ohms, 1 channels driven.) with 0.1 % THD, 20 Hz ~ 20kHz ................80W(BTL) with 0.1 % THD, 1 kHz ........................90W(BTL) Speaker Impedance................................4 to 8 ohms Frequency Response (at 1W, 4 ohms)......10 Hz to 100 kHz (+0, -1.5dB) Signals-to-Noise Ratio ...............................105 dB Total Harmonic Distortion - (at 20W + 20W, 1 kHz, 4 ohms, 24 kHz, LPF)......0.005% Dimensions (W x H x D).....................200 x 50 x 156 mm Weight..........................................5 lbs. 15 oz 1 Alpine 9886 1 Clarion APA250 100w @ 4 Ohms 1 Rockford-Fosgate 10" p2 1 Bassworx 10" Sealed enclosoure Link to comment Share on other sites More sharing options...
westsideboiii Posted January 23, 2008 Author Report Share Posted January 23, 2008 how can i do it now? can somebody please tell me? greetings 1 Alpine 9886 1 Clarion APA250 100w @ 4 Ohms 1 Rockford-Fosgate 10" p2 1 Bassworx 10" Sealed enclosoure Link to comment Share on other sites More sharing options...
westsideboiii Posted January 23, 2008 Author Report Share Posted January 23, 2008 BTW: I got this Subwoofer: http://sonicelectronix.com/item_8757_Rockf...ch+P2D210.html# The Rockford Fosgate Punch P2D210 Please help if you can!!! Once again: This Subwoofer has a Dual 2Ohm voice coil! Can i use this Amp to run the Sub? Yamaha YPA-300 Amplifier 35 W x 2 or 80 W x 1 @ 0.1% THD, 20 Hz - 20 kHz Continuous Power Output (per channel, 4 ohms, 2 channels driven.) with 0.1 % THD, 20 Hz ~ 20kHz .................35W/35W with 0.1 % THD, 1 kHz .........................40W/40W (per channel, 4 ohms, 1 channels driven.) with 0.1 % THD, 20 Hz ~ 20kHz ................80W(BTL) with 0.1 % THD, 1 kHz ........................90W(BTL) Speaker Impedance................................4 to 8 ohms Frequency Response (at 1W, 4 ohms)......10 Hz to 100 kHz (+0, -1.5dB) Signals-to-Noise Ratio ...............................105 dB Total Harmonic Distortion - (at 20W + 20W, 1 kHz, 4 ohms, 24 kHz, LPF)......0.005% Dimensions (W x H x D).....................200 x 50 x 156 mm Weight..........................................5 lbs. 15 oz greetings 1 Alpine 9886 1 Clarion APA250 100w @ 4 Ohms 1 Rockford-Fosgate 10" p2 1 Bassworx 10" Sealed enclosoure Link to comment Share on other sites More sharing options...
WickeD Posted January 24, 2008 Report Share Posted January 24, 2008 I really doubt that amp would push that sub at all.... and the only way i think you could hook it up would be to send 4 ohms to one channel. http://www.rockfordfosgate.com/rftech/woof...ohmDVC_4ohm.gif Link to comment Share on other sites More sharing options...
