Migz Posted November 26, 2012 Report Posted November 26, 2012 I've been trying to measure my bass amplifier output using my DMM, i know to get an accurate reading i also need a clamp meter but i just want a rough idea. I've got this DMM near enough. So i put it on AC which if im correct is the V~ settings just to the right of "OFF" I put my headunit up to where i think is about right, put a test tone of 40Hz on. Then i put my positive probe to the positive speaker terminal on my amplifier and the negative prove to the negative speaker terminal on my amplifier. It just comes up saying "1", but it says this on the digit all the way on the left of the screen, rather then the right. I've also noticed that when my headunit is between 0-10 it comes up with several thousand(Starts off in the hundreds but rises to several thousand as i go up), but sometime after 10 it just goes to 1 and sticks there. I've tried both settings under V~, i just don't know if its something im doing or if its because of my cheap DMM?
Guest Posted November 26, 2012 Report Posted November 26, 2012 what are the two numbers that are shown in the V~ section of your dmm.
Guest Posted November 26, 2012 Report Posted November 26, 2012 use 200. are you sure your probes are in the right terminals on the dmm?
321slapinbass Posted November 26, 2012 Report Posted November 26, 2012 I've been trying to measure my bass amplifier output using my DMM, i know to get an accurate reading i also need a clamp meter but i just want a rough idea. I've got this DMM near enough. So i put it on AC which if im correct is the V~ settings just to the right of "OFF" I put my headunit up to where i think is about right, put a test tone of 40Hz on. Then i put my positive probe to the positive terminal on my amplifier and the negative prove to the negative terminal on my amplifier. It just comes up saying "1", but it says this on the digit all the way on the left of the screen, rather then the right. I've also noticed that when my headunit is between 0-10 it comes up with several thousand(Starts off in the hundreds but rises to several thousand as i go up), but sometime after 10 it just goes to 1 and sticks there. I've tried both settings under V~, i just don't know if its something im doing or if its because of my cheap DMM? this might be a stupid statement but i hope your putting those on your speaker outputs and not the amps power and ground. 2000 Dodge Durango Subs - (2) SKAR VVX 15 D2's Box - 7.2 ft^3 @ 33hz, 120 in of port Sub amp - Digital Designs M2 @ .5 ohm Mids + Highs - PRV Audio Mids + Highs amp - Hifonics 2000.4 Headunit - Alpine CDE-100 Equalizer - Clarion EQS746 Batteries - Mopar group 27 + (2) C&D 52ah Wiring - 1/0 BIG 3, (2) runs 1/0 Alternator - Singer 250A 147.79 dB @ 35hz - burp - sealed on dash 147.47 dB @ 35hz - music - sealed on dash YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
Migz Posted November 26, 2012 Author Report Posted November 26, 2012 I've tried both, but will remember 200 in the future cheers. I assume so, i have the negative probe in the bottom (COM) and the positive probe in the middle as it says VAC on that one, im sure VAC stands for Voltage AC. I did try moving the probes to different terminals still using the AC setting but still nothing. Edit: Yeah don't worry, its on speaker terminals + and - not amplifier. Will ammend my first post
