XS Power Install
Correct, You fuse your power wire from battery to battery in both the front and back. The fuse between your rear battery and amp is to protect the amp and you fuse it accordingly to the amp's fuse rating. It would be like taking the place of the fuses if you were to be using a distribution block if you were running multiple amps.
  • Who's Online   1 Member, 0 Anonymous, 1202 Guests (See full list)
