What to add for LOUD AND CLEAR 300C
ThreehundredC
another question. i have 8gauge wire n fuse n ground.. the amp says it can fit a 4gauge which im guessing ill need. can i just cut the 8 inhalf and run then together as a bigger wire
Are you talking about cutting the rubber off of the wire and putting them together? I would just run 2 runs of the 8 ga into the amp, so you would have to sections of power and two sections of ground a total of 4 - 8 ga wires running into the amp. It will work but go ahead and get some 4 ga when you can.
  • Who's Online   1 Member, 0 Anonymous, 1696 Guests (See full list)
