ThreehundredC Posted December 13, 2012 Author Report Share Posted December 13, 2012 lol no. not cutting the whole wire apart just. making the 16 feet into two 8foot. sections and crimping to a connector or twisting the ends and stick it in the amp.. but since it was one wire. it has one fuse@ the end..would i need to add another fuse for the second run or could i somehow use the one fuse for the two runs to the same amp.. i already have a amp kit on order. so this will be temporary just cant wait two more weeks to get this thing up n running Link to comment Share on other sites More sharing options...
ThreehundredC Posted December 13, 2012 Author Report Share Posted December 13, 2012 so now i see why people use the toolmaker dual inputs. lol Link to comment Share on other sites More sharing options...
UMGixxer Posted December 13, 2012 Report Share Posted December 13, 2012 Try to run both lines into the one fuse holder, or just use the one 8 ga line until you get the 4 ga, thats probably what I would do Link to comment Share on other sites More sharing options...
UMGixxer Posted December 13, 2012 Report Share Posted December 13, 2012 Some of the more powerful amps come with dual power inputs Link to comment Share on other sites More sharing options...
ThreehundredC Posted December 13, 2012 Author Report Share Posted December 13, 2012 amp will run my doors and deck. 8s and super tweets Link to comment Share on other sites More sharing options...
UMGixxer Posted December 14, 2012 Report Share Posted December 14, 2012 You just confused me on that one, the only thing that you wire in series or parallel are the coils of the subs, but i probably would suggest using a class d amp if you are running subs Link to comment Share on other sites More sharing options...
ThreehundredC Posted December 14, 2012 Author Report Share Posted December 14, 2012 well ups says itll be here late tommarow i hope so.. BACKto speakers. has anyone use the american bass VFL 8s. found em local for the same as onlinr so i might get them Link to comment Share on other sites More sharing options...
ThreehundredC Posted December 14, 2012 Author Report Share Posted December 14, 2012 CAN ANYONE HELP ME WITH WTH TO PLUG THIS TO. chrysler 300 boston acustic amp bypass.. has two harness and other end wire Link to comment Share on other sites More sharing options...
ThreehundredC Posted December 14, 2012 Author Report Share Posted December 14, 2012 ? Link to comment Share on other sites More sharing options...
Guest Posted December 15, 2012 Report Share Posted December 15, 2012 dont bump your thread after an hour. its made specifically for the boston acoustics amp in your car. so its obviously clear that you use it on the harnesses that go into the boston acoustics amp. there are likely instructions. i see them in the picture. edit: by the way, a 4 channel is fucking useless for subwoofers. use monoblocks. Link to comment Share on other sites More sharing options...
