Loud & Low 8th Gen Civic - Time to say good bye to her.
Which unit you like better? Or you always had the 9500? Sorry can't remember lol
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Reason I ask about the 80prs is it's option to run tablet mode or whatever it's called
Where you basically use it as a pass thru to send the tablet signal to the amps.
It's also active (not as good an eq), but it lets you dump your 360 and it's issues.
As far as I know, optical from an ipad is essentially no better than 30pin or lightning out, because it has to be processed to be converted to optical, and it's not up converted.
This may be way different for your note, but it's something to look at.
Regardless, clean up your harness before making any moves, and add another ground into the harness that grounds to your steering cross bar or something like that.
I've had success with that eliminating whine
Yes I have a lot of stereo weight. I build for Smiles Per Gallon not Miles Per Gallon LOLZ
My build - 1996 4Runner with 2 18s - 149+ in a sealed box (with radiators)
0a4ee87c-28c8-4bf8-9dfe-5a06b9dea2dc_zps
3e3eb9dd-70f8-4424-ad11-ccebcd929ac4_zps
I don't remember tablet mode or mobile mode or anything. But I'll take your word for it. I'd still have to find a spot for it though.
I've tried it and I can tell a noticeable difference between the RCA's analog 3.5 conversion, and the HDMI adapter+HDMI converter+Optical with the entertainment system at home. Even the HDMI converter does RCA out, and that sounds considerably different that the optical.
I'll clean things up behind the unit for sure. I'll have to deal with this for a bit until I can get the tablet mount built etc.
They're pretty comparable Evermaxx. The 80prs has the processor built in, but doesn't have hd radio which was what I wanted back then. I don't remember why I sold the 80prs, but I'm sure I had some good reason. I bough the 9500 cause it was on sale and a good deal. It's a good unit, and pretty close to the same as the 80prs, just no processor.
Yeah that's one of the things I have to worry about, but my biggest concern is how to operate this thing: https://www.octavainc.com/HDMI%20distribution%20amp_splitter%202%20port.html I'm at work so obviously I don't have it with me, but I can give you the specs when I get home of what the plug numbers are, unless you can find it on there. I just didn't want to have to do a converter if I could avoid it.
Unfortunately you are going to have to use the MHL adapter to get HDMI out from your Galaxy 8.0. I wouldn't use something that big as there are much smaller digital converters.
Here is one for cheap and you won't have to use the one from your house. Plus it operates at 5V so you would just need to buy a voltage converter.
http://www.ebay.com/itm/ViewHD-Premium-HDMI-to-HDMI-RCA-L-R-TOSLINK-Audio-Extractor-Converter-2013-/271331213223?pt=US_Audio_Cables_Adapters&hash=item3f2c99bfa7
http://www.ebay.com/itm/SUPERNIGHT-DC-DC-12V-24V-to-5V-10A-Converter-Step-Down-Regulator-Module-50W-/261322520291?pt=LH_DefaultDomain_0&hash=item3cd80936e3
http://www.mcmelectronics.com/product/83-15446?scode=GS401&CAWELAID=530004080000121100&catargetid=1606964484&cadevice=c&cagpspn=pla&gclid=CJCa-4bS-bwCFUVo7AodpDEAOA
2009 Nissan Maxima SV Super Black KH3
  • Hardwired Beltronics 955 Radar
  • Pioneer DEH-M9400BH with Stock Bose Speakers
  • Custom fiberglass HVAC display
  • Nexus 7 Tablet w/ Custom Fiberglassed Magnet dock
  • KnuKonceptz Big 3 and wiring
  • 2 Alpine Type E 10's with Alpine MRP-M500
Build Log HERE
Oh okay, yeah only thing I don't like about mine is HD Radio but I hardly listen to the radio
Team Subsonic Lows
  • Who's Online   0 Members, 0 Anonymous, 530 Guests (See full list)
