wellington Posted December 5, 2012 Report Posted December 5, 2012 Is it possible to get an air hopping setup in a 2010 HHR LT? Most of the vids I see are just slow raising and lowering. 2010 HHR LT - DNX 6160 - sony xec-700 - sony xm-4040 for door mids - XM-6020 for tweets in a-pillar - saz1500d v1 - VVME RD-12 1.75 f^3 32hz guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club
xx1 Posted December 5, 2012 Report Posted December 5, 2012 it is possible, specially with nos, audio related merchandise (decals,banners,lanyards,hats,shirt,etc)
OrangeJuiced Posted December 5, 2012 Report Posted December 5, 2012 Yup definitely possible. 1/2 valves and lines. Along with about 200-250 psi out of a nitrogen bottle. My uncles is hopping a 95 full size Sierra with 24's. as far as for a daily driver, not recommended because doing that leads to tons of mechanical failures especially if you haven't taken the precautions to support the hopping. 2001 GMC Sierra Build. Body dropped and Juiced
StreetMetalBen Posted December 5, 2012 Report Posted December 5, 2012 Controlling the speed of you lifting ability is quite easy. But hopping might be a stretch If you added a nitrogen tank to your air system, and run valves that are rated to Approx 600Psi
StreetMetalBen Posted December 5, 2012 Report Posted December 5, 2012 Yup definitely possible. 1/2 valves and lines. Along with about 200-250 psi out of a nitrogen bottle. My uncles is hopping a 95 full size Sierra with 24's. as far as for a daily driver, not recommended because doing that leads to tons of mechanical failures especially if you haven't taken the precautions to support the hopping. Correct, Defiantly not a good idea for a DD
wellington Posted December 5, 2012 Author Report Posted December 5, 2012 Ok, wont go for hopping then. What would be ok as a daily driver then? 2010 HHR LT - DNX 6160 - sony xec-700 - sony xm-4040 for door mids - XM-6020 for tweets in a-pillar - saz1500d v1 - VVME RD-12 1.75 f^3 32hz guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club
OrangeJuiced Posted December 5, 2012 Report Posted December 5, 2012 You can bag a vehicle and have it relatively reliable. If you have no experience, dont take on the task. As far as a dd I think something along the lines of a viair 480 and a 5 gallon tank would be good. Streetmetalben could recommend the products better. He works with them a lot more than i do. I do know that it is not cheap for quality products and quality install. 2001 GMC Sierra Build. Body dropped and Juiced
