2004 dodge dakota z v3 15 build
Box is done and playing! I got a crap load of work done the past few days. The whole inside of the Box was sanded smooth and painted with 2 coats of black enamel for the smooth ness if it even helps. Wire came in yesterday so I called a buddy to help me move this thing son of a bitch was heavy atleast 150lbs I have many pictures to post and possibly a video after work tonight at 10pm. I'm flexing like a mofo too =] definitely need deadener in the spring
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
like i said heres some updates: got the sub all wired up with audio technix 8ga 0fc hopefully i will be buying a some ofc 0ga from them aswell with my tax return.
Heres the port all smoothed out and painted
Heres the sub all t nutted in
This thing is huge! luckily i didnt have to remove my lower trim panels =)
Heres the battery and messy wiring, i plan on fixing after i paint the box
heres my center console all wrapped up
i couldnt get a good video, ill see what i can do tomorrow, its flexing hard!
Nice truck. I have a 2000 Dakota 5.9 V8 with a DC Audio M2 XL 18 with custom red basket, direct leads, extra spiders, upgraded surround, d1.4, and red carbon cap. It's running off a Crescendo BC2000d with Kinetik HC-1800, Big three upgrade but stalk 140 amp alt.
I have nothing bad to say about this stock alt, it seems very strong. Lowest i will drop to sitting at a red let foot on the brake 650rpm is 13v I usually charge 14.3-14.8 depending on the temp
I would agree. The only time it charges less that 14.5 is when its warm out. Most of the time its between 14.5-14.8. With my XL, Crescendo, and kinetik I still get some voltage drop no more than 1v When on it drops from say 14.5 to 13.5 at worst.
Im hoping to be able to add another 4 channel something that does 125x4 at 4ohms i think i should be alright on my electrical its only stereo power anyways. Tax time is coming up as well, im planning on a 51 inch tv and some power wire if i have enough left
