A decent amp
Iknownothing
We were wired at 1ohm when we clamped it if I remember correctly. But will rise it was around 2.xx ohms.
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
if you want a 3k from hifonics go with the colossus i have one and its puts out alot of power.. very power hungry amps
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Second skin damp pro
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
50ft Rockford fosgate ofc 1/0
3000Watt is claimed at 1 ohm... I can't vouch for this series... Sonic Electronix lists it as CEA-compliant, meaning it will put out rated power...
from what i've read, companies can just buy the CEA sticker and slap it on their product. sundown isn't CEA certified last i checked and all their amps put out more than rated.
CEA-2006 Compliant
On May 28, 2003, the Consumer Electronics Association published standard CEA-2006, "Testing & Measurement Methods for Mobile Audio Amplifiers." This "voluntary" standard advocates a uniform method for determining an amplifier's RMS power and signal-to-noise ratio. Using 14.4 volts, RMS watts are measured into a 4-ohm impedance load at 1 percent Total Harmonic Distortion (THD) plus noise, at a frequency range (for general purpose amplifiers) of 20 Hz to 20,000 Hz. Signal-to-Noise ratio is measured in weighted absolute decibels (dBA) at a reference of 1 watt into 4 ohms. This applies to both external amplifiers and the amplifiers within in-dash receivers.
CEA-2006 allows consumers to be able to compare car amplifiers and receivers on an equal basis. Manufacturers who choose to abide by the new standard are able to stamp their products with the CEA-2006 logo that reads: "Amp Power Standard CEA-2006 Compliant."
Amplifier Power for Mobile Electronics, CEA-2006-B
Program Description
The amplifier power for mobile electronics logo indicates that a car amplifier has been tested to CEA-2006-B, testing and measurement methods for mobile audio amplifiers. The standard requires that the manufacturers report at least three ratings: primary power output in watts, total harmonic distortion plus noise and signal to noise ratio.
It's partner mark, the mobile loudspeaker logo, indicates that a car loudspeaker has been tested in accordance with CEA-2031, testing and measurement methods for mobile loudspeaker systems. CEA-2031 defines test procedures for rating the performance and physical size of mobile loudspeakers and requirements for reporting the performance.
When consumers use the information found with both logos, they will be able to select mobile loudspeakers with power handling capabilities that are appropriate for the power output characteristics of their mobile amplifiers.
Examples of Product Mark Usage
Power Output: 30 Watts RMS x 4
Channels at 4 Ohms and 1% THD+N
Signal to Noise Ratio: 80 dBA
(reference: 1 Watt into 4 Ohms)
Dynamic Power: 60 Watts at 4 Ohms
Frequency Response: 40 Hz
to 18,000 Hz (3dB)
Additional Power Output: 35 Watts RMS x 4
Channels at 2 Ohms and 1% THD+N
Participation Steps
Email CEA's product mark administrator at [email protected] and specify what logo you are interested in obtaining.
CEA's administrator will email a PDF version of the agreement with directions on how to fill it out and return it properly.
Acquire the latest revision of CEA-2006-A and rate products in accordance with the standard and the license terms.
Pay the annual administration fee of $100 per model which caps at $500 for five or more models bearing the logo per calendar year or part thereof.
If relevant, provide CEA an annual list of models bearing the logo.
This is stuff I pulled from a few sources. So, yes, the companies have to buy the decal, but they have to rate their amplifiers in accordance with the standards. Can you please refer me to some of your sources, maybe there's something I'm missing.
2011 Chevrolet Aveo(click for build log)
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
Knukonceptz 1/0 Kollosus Fleks Cable
8 AWG Sky High Car Audio OFC
1/0- Sky High Car Audio
2- XP3000 XS Power Batteries
SMD VM-1
2- 12" Ascendant Audio Mayhems
Toolmaker Fuse block
Toolmaker Bus Bars
(Last Season scores 1-15" Mayhem)
145.2 dB- Sealed @ NSPL World Finals (9/28/14)
148.1 dB- Hardcore @ NSPL World Finals (9/27/14)
150.23-- Hardcore on 4500 Watts!!!!
New Build (2015, 2-12" Mayhems)
146.9- Sealed on dash
149.6 dB- Hardcore in Kick (No wall 0-24" Hardcore)
  • Who's Online   0 Members, 0 Anonymous, 1335 Guests (See full list)
