95 honda civic hatch build
so i paint the interior plastic black and added poly fill in the rear
patched some holes
working on amp rack and subbox locations (who needs backseats)
so for equipment
pioneer 4000ub deck
kenwood eq
audiopipe eq
5 1/4 inch cliff design components
4 inch sound stream
sony xm450 speaker amp
incriminator audio 20.1 sub amp
2 - 12 inch mach5audio spl subs
trying a 6 1/2 t-line box tuned to 40hz
so here a pic of one of the mach5audio subs
also put resin inside the box
and added 8 gauge speaker wires
made t-line for the 4 inch speakers tuned to 200hz for a little mid bass
also did some work on the paint
started with rolling on a 50/50 mix of mineral spirits and tremclad (rustoleum)
put on alot of coats
then with 4 rattle cans and a plastic bag did this
total cost was around $35 , will probably go back to black in the spring
built a lower consol to the eqs and a voltmeter on the sub amp that i can switch on or off
have 2/3 of big 3 done , i just have to go positive to alternator
already replaced alt ( need a mechman )
have different ports length starting at 33hz going to 53hz
have a coolant problem right now , have to replace rad
have pull out system for winter but next year
going to be running 2 ia 20.1s
2 sony xm450
upgrading doors to 4 sets of 6 1/2s
rear stage will be 2 sets of 5 1/4s
rebuilding subbox
adding isolator and some batteries
never got the car metered :(
Nice equipment you have there... seeing that hatch makes me miss mine I had 9yrs ago. And which model are those Mach5?
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
