Birdgang502 Posted December 20, 2012 Author Report Posted December 20, 2012 They are definitely wired correctly... Like u said all positive one one line... All negative on another... I have checked a few times
Birdgang502 Posted December 21, 2012 Author Report Posted December 21, 2012 So I've hooked a oscope to everything... No clipped signal but subs barely hit!?!? It's an 1800 watt amp, what is the deal??
Sonic Posted December 21, 2012 Report Posted December 21, 2012 What's your enclosure like? give some details, tuning, port area, dimensions etc.. The type r needs closer to 2 cuft to really get going.
Birdgang502 Posted December 21, 2012 Author Report Posted December 21, 2012 It's the ground shaker prefab box... Single chambers 1.35 vol not sure about tuning or anything
Guest Posted December 21, 2012 Report Posted December 21, 2012 burn the box. get a design from somebody on here and build your own. something is still wrong though. i'm willing to bet its user error.
Birdgang502 Posted December 21, 2012 Author Report Posted December 21, 2012 Is it possible to fry my HU if probes touched while testing output from RCA... My HU is all screwed up now... The eject button is now the source button wtf
Birdgang502 Posted December 21, 2012 Author Report Posted December 21, 2012 Kranny ur just a freaking genius aren't you... You make an awful lot of assumptions yet you can't tell me what's wrong
Guest Posted December 21, 2012 Report Posted December 21, 2012 its possible. shorting things out can cause electronics to be screwy. i still dont know why you're testing preout voltage. there is no reason why you should be doing that.
Sonic Posted December 21, 2012 Report Posted December 21, 2012 Yes, burn the box and get a good design and build one to specs., also your settings on the hu probably messed up and now seems like you have messed it up even more.
Guest Posted December 21, 2012 Report Posted December 21, 2012 Kranny ur just a freaking genius aren't you... You make an awful lot of assumptions yet you can't tell me what's wrong listen bud, do you realize how hard it is to diagnose someones problem without actually being there? thats like me calling my mechanic saying that the A/C doesn't work and how to fix it. well how the hell should he know what the problem is when there are so many things that can cause it? same thing with computers. oh the computer doesn't turn on? that can be a million different things. motherboard could be bad, psu could be bad, shit maybe the power cable isn't seated properly.
