I had oscope on RCA testing signal to find out max volume and also making sure HU output is sufficient enough
99.9999999999999999999999999999999999999994% of the time, preout voltage doesn't matter. all you should be caring about is how clean the signal is. you can tell the voltage of the sine wave through the scope readout as well.
frustration is understandable. i'd be frustrated too if my install didn't work as i intended.
do the woofers even move a decent amount after you tuned everything to output max clean power?
edit: did you try tuning with the sub level at +10
They barely move once tuned with clean signal... They move like crazy and rattle windows when I feed dirty signal so I'm wondering if I just need bigger amp so I'm not sending dirty signal or what
It seems like it's a typical case of not having right enclosure, hence, not getting the output you expected, and trying to squeeze more out of the system by making adjustments, thats probably why the subs started to heat up. What could also be an added factor is the hu settings like the filter if it have that option.
I turned off all filters on HU... I get the sound I want of of subs in current box but only when sending overloaded/clipped signal... For instance... Play song with amp putting out 42.24 v clean signal sounds like one 10"... Play same song with amp putting out around 56v dirty signal and sounds like I have thunder going off in my car, bass so loud it vibrates your throat and makes the shirt I'm wearing vibrate
  • Who's Online   0 Members, 0 Anonymous, 1208 Guests (See full list)
