van klan Posted December 22, 2012 Report Posted December 22, 2012 What's the best way to wire two batts. And a batt. Cap together? If hes tailgating let him pass, pull up behind him and rattle his mirrors off....
dereileak Posted December 22, 2012 Report Posted December 22, 2012 you need to be more specific 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
van klan Posted December 22, 2012 Author Report Posted December 22, 2012 Iv got a battery up front and a capacitor in the rear I'm wanting to add a second battery to the back and maybe throw the capacitor in there as well do I just hook up the positive lead coming from the front battery to the positive of the rear and then to the amp? If hes tailgating let him pass, pull up behind him and rattle his mirrors off....
dereileak Posted December 24, 2012 Report Posted December 24, 2012 Iv got a battery up front and a capacitor in the rear I'm wanting to add a second battery to the back and maybe throw the capacitor in there as well do I just hook up the positive lead coming from the front battery to the positive of the rear and then to the amp? If I were you get rid of the capacitor, whenever you connect battereys you always fuse within 6 inches of the + battery terminal on both sides, do you have a High Output Alternator? and what type of batteries do you have?, here is a picture I made to show that fusing: you have to fuse on both ends, because the + cable between the batteries if shorted will pull power from both batteries, and if you only have a fuse on one side it will still have a connection with the other side 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
