Lights Dimming?? Ford Diesel on 2400 watts
Well thats not helping.. who knows how well the seats themselves are grounded to the body of the truck, let alone to the frame after that. Run a ground cable or two into the cab to use as proper grounds. Can bolt everything to the seat if you want rather than having a distribution block.
Any speakers blowing isnt likely due to the grounds though, just poorly balanced system.
Hammerdown... 1%
Yeah ten 4,
Were just waiting right now until he gets money and were guna run 0 gauge to the amps since the terminals except it and do the big 3/4 up front and see if that helps with his voltage drop
Well also redo the grounds when we switcg to 0 gauge
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
