New alternator, big 3, or what?!?!
Also, just noticed this is in general audio. OP next time put this in "Electrical". You notice how at the top of this sextion it says "general audio is not a dumping ground" lol.
Thanks for all the help guys. I was waiting to see what alaskanzx5 had to say, always on top of things! Lol. If i can find someone to do the big 3 on my car for cheap i will def do that. But if i cant, then i will get maybe like a D2400 or 3100 up front for my T1500, and a D680 for the T600-4. Hopefully ill be alright!
2007 Volvo S40 2.4i (no turbo :( )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Yah i know, but this was kind of a general question. But ill make sure to put it in the right place next time, thanks
I think the point Mike was making is, you may not need a 250amp alternator if your amplifier draws 250 amps. Because you have battery reserve. I have not seen a single build on here where there is substantial current draw that did not have multiple batteries even with large or multiple alternators.
You don't want to rely solely on your alternator for your power. I mean, if you have a high output alternator and a lawn mower battery you have issues.
Like i said, musically you might see high current draws here and there, maybe even for two or 3 seconds. But unless you listen to constant tones at full tilt for long periods you should be ok. You just have to use some common sense. That's why i say, get a volt meter, a couple good batteries, Big 3, and keep an eye on your voltage. If you are having issues, then you may have to upgrade your alt with a universal fit, or make a bracket and try to squeeze in something.
In short, it's okay to have a mid level alt or not even have enough alt for your power needs, just back it it up with battery reserve.
Also, Talk to mechman or Singer about a universal fit, or maybe a different body alt using a custom bracket. I think they don't volunteer that fact for liability issues. But if you outright ask for it they can give you some more options. Good luck o.p.
  • 3 weeks later...
Big 3 can get you UP to 25% increase in power/ current flow. Definitely do it, definitely 0 ga. 150 amps for a stock alt is impressive. I am confused why you need to spend 300 to tear halfway through the engine, is your batt under the hood that buried?
35% front, 5% tint rear/windshieldKenwood KDC-152Knu RCA'sInfinity 6.5 kappa perfects1/0 Knukonceptz power/ groundBig 3 in 1/0Kinetik HC 1400 in rearCustom slot ported box @ 35 HzNVX JAD 1200.12 Sundown SA-12 Double layered NVX Audio Deadener
FUTURE BUILD:
-2 Sundown Nightshade 12's D1 w/ Zv3 softs (HAVE)
- DC 3.5k (HAVE)
- 2 pairs of Skar RPX 6.5's, Skar RPX 6x9's , 4 Skar audio Bullet Super tweeters ( HAVE )
Undecided on box, amp(s), HU, and power supply.. and vehicle for that matter.
For your alternator, if you can't find a place that sells one, or will make you one, talk to Singer. He was only person that offered to make one for my MINI.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
  • Who's Online   0 Members, 0 Anonymous, 393 Guests (See full list)
