jasonv31 Posted December 25, 2012 Report Share Posted December 25, 2012 I ordered two of the new Sundown E8 v.3 D4's need some advice on the best sub box placement and design. Please bear with me this is my first post on SMD! :-) I have a 1999 Isuzu amigo, custom vortec v6/4l60e drive train out of a 2004 chevy blazer (swap done by me) and I have the shop (new one being built!) and mostly the skills and equipment to build my own box, have built several sealed ones over the years and worked at a furniture factory and custom cabinet shop years ago. (OK enough rambling) This is the rear area of my amigo ... As you can see my space is limited. Well... limited because I want to keep as much of the floor area as possible, one of the reasons I went with the 8" and not a bigger sub. Also the sundown 8" fits in a small area even ported. For this 8" they recommend a ported box so I have a few possible configurations based on my truck. (The E8 v.3 D4's has a recommended 0.5 to 0.75 ported box tuned to 35hz.) 1- I could do two enclosures on each side, both firing towards each other. Essentially I could gut the plastic panels on each side that "hide" the roll bars on each side. The area behind there could soak up some of the box area and the rest could intrude minimally into the cargo area. It would be more work than the next option and I dont have a problem with that, but would it sound good? For this direction would the port be best on the front or firing up into the cabin ? I say this because although the ports and drivers would be the width of the cargo area apart (Likely a bit less than that once the boxes are in) would the opposing subs firing at each other impact the sound ? (SPL and SQ) 2- I could build one large enclosure (with two or one chamber) in a down firing configuration that would as thin a possible (maybe 6-10 inches) and after complete would have a false floor appearance. I could leave a space towards the front of the box (portion that is closest to the rear seat back) that the sub port could exit, leaving space for the length of the port. I ran this very roughly in a box calculator and it is possible. So after all this what do you think ??? Please ask questions ... I know I may have left some things out or unclear.... lol Quote Link to comment Share on other sites More sharing options...
jasonv31 Posted December 25, 2012 Author Report Share Posted December 25, 2012 I wanted to add... if you have any other ideas on enclosure design even outside of the ones I listed please sound off!! I want to hopefully build this once ... at least once until I get some new subs ! LOL ... Quote Link to comment Share on other sites More sharing options...
soBASED Posted January 7, 2013 Report Share Posted January 7, 2013 A smaller box with more power using an aero port should save you space. I got a v3 in a .66^ft tuned to 35hz on 520 watts and sounds great! Quote Car:- 2013 Honda Accord Sport 6MT - aFe SRI Electrical: - Big 3 w/ Execution Audio 0/1 AWG OFC- Stock Battery Audio: - JBL Power Series 6.5 Comps up front (Running off HU power atm) - JBL Power Series 2-Ways in the rear deck (Running off HU power atm) Subwoofer: - Sundown Audio X-15 - CT Sounds AT1400.1D (@1 ohm) Bedroom: - Yamaha RX-V365 - Pair of Klipsch KG4.2's - 2 E8v3's in a 1.34ft^3 tuned to 30hz - No Amp yet.. - CoolMax ZU900B PSU for amp In my room & previous car:- Amp: Soundstream TX1.1300D @ 4 ohms (520 watts)- T-Line Enclosure tuned to 32hzYouTube : http://www.youtube.c...r8?feature=mhee Link to comment Share on other sites More sharing options...
Thumpersplbassx Posted January 7, 2013 Report Share Posted January 7, 2013 Subs up port back would work too. 2 cubes net tuned to 35hz Quote 1 pr Sundown Audio Sa Cs 6.5 component set 1 Sundown Audio sax 125.4 4 Sundown Audio sa8v2's 2 1500's strapped to 2ohms 1 Tenney 270 alt Link to comment Share on other sites More sharing options...
stroupe79 Posted January 7, 2013 Report Share Posted January 7, 2013 first I will just go off your ideas 1. with the 2 enclosures on each side, it is just more of a pain in the ass than it's probably worth 2. most of the enclosures I see either have the port facing the rear tailgate or up toward the ceiling(sometimes they aim toward rear quarter) toward the tailgate would be ideal I would recommend you build a single enclosure with 1 port in the center of the box between the subs and have everything facing the rear, now if your planning on using the cargo area and are worried about damaging the subs (reason for downfiring enclosure) you could still do down firing subs and port to the rear.. maybe somebody else has a better idea Quote http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup) Link to comment Share on other sites More sharing options...
jasonv31 Posted January 7, 2013 Author Report Share Posted January 7, 2013 I was looking at downfiring for three reasons, to minimize damage (I run a soft top in the summer, throw shit back there etc), so if i want to haul something small I still can, I was even looking at putting a rubber suv mat on top of the box, and finally to make everything more secure and more hidden. I even plan on lag bolting the box through the floor to make damn near impossible to steal:-) As far as the box goes I've narrowed it to a folded horn design (similar to some by decware) or a ported design down firing subs with port/s firing to the rear leaving a several inch space between the box and door for the port/s or horn. The horn will be much more complicated but much nicer, however even with a 8 I may not have enough space for how I want it mounted in the rear. I will post back what I come up with.. got my E8v3's in the other day, also picked up a used sundown 1000d. Its gonna be sweet! Thanks everyone for the comments! J Quote Link to comment Share on other sites More sharing options...
