Rebuilding speakers help
Hey guys I have an old pair of 15 inch home woofers that i wanted to redo completely.. I'm going to do them one at a time and i already bought most of the things i need.. I have the cone w/ surround, gasket, spider, and dustcap.. i bought two coils but when i tried to test fit it into the gap it was slightly bigger by a cm...I have two questions
1) The old coils are not blown and they seem to be in pretty good shape.. i was able to clean off the old glue from it.. would I still be able to use this coil instead of buying new ones?
2) What glue would you recommend? Are there different glues for gluing the spider to the coil and the cone to the coil as opposed to the one used on the gasket and surround?
This is my first time doing it so any help at all would be appreciated. I would really like to do this by myself and not take it to a shop.. it's one of those things I want to do before I die and doesn't have to be perfect lol
2008 BMW 550i M Sport
Build coming soon!
2000 Volvo s40 1.9T
Pioneer DVD navigation head unit
O2 audio performance mid range speakers
2 Crescendo PWX-6 Pro Mid Range Speakers
2 Crescendo PWX-8 Pro Mid Range Speakers
4 Selenium ST200 Super Tweeters
Hifonics ZRX2000.4 Amplifier
2- 12 inch DC Audio Level 4 m2
Hifonics Brutus BXI-1610D Amplifier
2 KinetiK HC1400R- Secondary Batteries
Kinetik HC600- Secondary Battery
Knukonceptz 1/0 gauge big 3 upgrade
what glue did you clean off the voice coils....glue is what holds the windings to the former. if there is no glue then the coil will unwind, ruining it completely.
I didn't touch the actual copper on the coil.. i cleaned off the glue that was holding the coil to the old cone on the opposite end of the spool of wire.. when i took it off it left some of it on and i cleaned it so it's flat again
Build coming soon!
2000 Volvo s40 1.9T
