brad4021 Posted January 27, 2013 Report Posted January 27, 2013 believe me, the more air you can have the better. nothing worse then going to hit a switch and your out of air.
brad4021 Posted January 27, 2013 Report Posted January 27, 2013 and even if you have more comps to keep up, if you are mounting the comps in the car then it would be really annoying if they were running every time you hit a switch. I have 4 compressors and 2 5 gal tanks in my truck and it just about cleans them out if i lift from laid out but like you said my bags would be much bigger then what will be in the car. also if you can find a good fab shop they can probably make you some custom tanks to fit in dead space under the car? just an idea i would look at accuair. they have some really nice kits and their valve blocks are amazing. i run their stuff in my truck and it seems like pretty much every dang bagged car out there is running their stuff now. also they make it all plug and play so it is truly a no brainer. spend the money once and do it right so you never have to redo it
