kaydennicholson Posted February 1, 2013 Report Posted February 1, 2013 I have a Hifonics Brutus BRZ2400 amp and (2) 2 ohm DVC subs. i have the subs separately wired as there are two terminals on the outside of the box. both subs are wired at positive to neg, and the other pos and neg to box terminal, same on both sides giving me a 2 ohm load on both sides. My question is what will be the final load if i hook both terminals up into the amp individually, using both positive inputs and both negative outputs on the amp? still a 2 ohm final load or what?
OG BudBone Posted February 2, 2013 Report Posted February 2, 2013 http://www.the12volt.com/caraudio/woofer_configurationsm.asp?Q=2&I=22#_index 1997 Trans Am WS6 Pioneer DEH-P5200HD 2 DC Level 4 M2 12s 4 cubes tuned to about 34hz DC 3.5k 1/0 Welding Supply Ultra Flex Stock 140A alt Stinger Fuses & Fuse Holders XS Power D5100 XS Power XP3000
