box & woofer question
vw passat
iv just made a new box and i went for a drive this afternoon. i was playing decaf songs and my volt meter was at 12.8 - 13.0v at full tilt
and my woofer stuck (spl 380d2) and i have 2 batteries AGM varta. what do u thing guys about this problem my voltage or the box dimensions like port area and port area per foot and when i come to play 2 chainz my moment decaf it sounds like crap. thats because it dosent go low enough? this are my box specs can someone tell me what thinking is my problem pls
you have a 15? it looks like you could use a little more port area to to volume ratio, but you're just under what it should be (14-17 in^2 / ft^3)
you're tuned to 35, but chances are your car peaks at a higher frequency than 35.
what low frequencies doesn't it do well at?
depends on the vehicle. depends on box orientation. depends on if the door/window is open or closed. depends on which side the port is facing.
battery voltage doesn't dictate how low a woofer can play. it just dictates how much power the amp can produce.
you still don't seem to realize (after i've explained it multiple times) that port area per foot is just port area divided by how big the box is. it tells the same amount of information.
show pictures of the box. maybe you built it wrong.
i dont know my car freq but when i had a box tuned to 40hz and iv play rack city the sound it sounds like crap so what i need to change fron the box and do u think what happin to the woofer (stuck) because the box it build wrong? btw my car is a vw passat tx guys
It sounds like you're trying to play songs that hit too low for your setup. If I remember right, My Moment hits 25 hz. Your subs are probably flailing about uncontrollably when it tries to hit that note. Set the subsonic filter on your amp to about 30 hz and it should clean it up a bit.
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
  • Who's Online   0 Members, 0 Anonymous, 900 Guests (See full list)
