need help on how to connect this voltmeter to a switch then to the amp.
If you dont mind the work you put into the housing for this going to waste you could always get a stinger like everyone has. Who knows if you remove the plastic case it might even be a close fit.
If you get alot of items from amazon I recommend the Prime membership. its $80usd / year. free 2 day shipping on everything and 3.99 for overnight.
Going off of what you typed on how the seller wanted you to hook it up the red should go to a constant or ignition power, black to ground and blue to the amp positive. The voltage at your amp is not going to be the exact same as where you hook the red wire to unless you run the red wire to the amp positive also.
  • Who's Online   1 Member, 0 Anonymous, 1408 Guests (See full list)
