Jessica Posted February 10, 2013 Author Report Share Posted February 10, 2013 This seems to be a common issue 3 common wall boxes. Normaly in a small box you could put the sub close to the port and load off the port wall. I don't really have that option. You guys think moving the subs as far from the port in this enclosure should help with cone control? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Jessica Posted February 10, 2013 Author Report Share Posted February 10, 2013 All i can do really is move the left side over 1" and the right side 2". The upper wall on the left limits how far left i can go. Would look like this if i did that. Maybe AMI can chime in on this too. edit: I'd rather just put the port down the middle to make it easier but then again i hate to split the port in half at the back because the port ratio gets out of whack. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Quiet Posted February 10, 2013 Report Share Posted February 10, 2013 Throw a divider wall between the left subs and right subs. Might help to angle the back towards the left subs a bit.better than my suggestion. 2007 Pacifica Rebuild. Less quiet. Still not loud. Link to comment Share on other sites More sharing options...
Jessica Posted February 11, 2013 Author Report Share Posted February 11, 2013 Well, i have the seat out of the car and the design has changed. I will post that some other time when I get ready to build. But, the new design is much more simple and is just a cube now with no angles. I also did some research on MDF weight per sqft and 2X4 weight per linear ft and it looks like with just the box and subs i will be around 450lbs. So Wednesday I am going to load the car with 500 or 600 lbs of weight and see how it sits. One nice thing is most of this enclosure will be just in front of the rear axle and partially on top of it. I'm hoping that will reduce some sag. If not i will be looking for some better springs. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
