I have a four door truck and the back doors rattles so bad. It sounds god awful. I have sound deadener on the door panel and all over the inside if the door and it still does it. Any tips to stop this?
(2) PSI p2 18's
Crescendo 2000
Audio Technix 0 gauge/ SHCA 0 gauge
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
Great Stuff \m/
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Most likely, if you layer the door with masking tape and spray the foam over the masking tape then you can always take the foam out, but since it's in a cramped place like a door idk if that will be easy or effective.
Edit: Although.. It IS inside the door, if I understand correctly. So it should hardly matter to whoever is buying it unless they wanna get in the door for some reason.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
I thought about kinda building a wall outta mdf to cover up the door. Idk if that will work tho
(2) PSI p2 18's
Crescendo 2000
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
Don't think it would.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Just wait for some pro's to chime in.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
  • Who's Online   1 Member, 1 Anonymous, 586 Guests (See full list)
