Noobish question of dual slot ports. Please help me!
FosgateLife
Ive always been confused about how to calculate 2 slot ports in a box... Do you just combine the total or what??
Im trying to build a final, friken amazing box for my SSD but i cant figure anything out and it pisses me off because i cant find anything that helps me. So please HELP MEEE!!!!!
If someone could point me to a free box designer that'd be awesome too :) lol
The area i have to work with is 15 high, 15 deep, 40 wide. Im wanting to have over 2 cu ft of airspace (ssd's like bigger boxes) so if someone could help a brotha out i'd greatly appreciate it!
2007 Volvo S40 2.4i (no turbo :( )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
I use torres and i want to make sure im putting in all the length and everything in correctly.
Want im wanting to do is make a box for my SSD 12, sub in center. Dual slot ports on each side. Lots of port area, still having over 2 cu ft of airspace
generally speaking it's total sq in of port x length.
You do suffer losses running more than one port because of port wall friction is increased due to the high wall-area:port-area ratio. It lowers your tuning a little bit because the extra friction slows down the air. in most designs it's negligable though but in a 4th or 6th order it can considerably affect your tuning.
you should be ok
2007 Pacifica
So basically, i design a box on torres... And whatever the port dimensions are, split them in half and make a port on each side?
yeah
Thanks! I will post a picture for people to revise later!
Let me know what you guys think and see if this looks good!
In the future you could just do a print screen :)
I dont think im gonna split the port in 2... im gonna make a one sided port and just make it the appropriate length
  • Who's Online   0 Members, 0 Anonymous, 2702 Guests (See full list)
