graham0599 Posted February 21, 2013 Report Posted February 21, 2013 I'm looking to build 2 custom towers for my home system and i plan on using1 - 12" woofer 80-350 Hz2 - 8" midrange 300-3000ish Hz1 - tweet 3000ish Hz and upper towerWhat i need help on is designing some crossovers or having them made. Also should i get 4 or 8 ohm drivers? I plan on temporarily just running them off my receiver then probably getting a pro audio amp later. If i left anything out, please let me know. Thanks for the help My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
graham0599 Posted February 21, 2013 Author Report Posted February 21, 2013 Bump! My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
Justin248 Posted February 21, 2013 Report Posted February 21, 2013 If you are looking for preassembled passive crossovers then http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-150 those look about where you wanted. I would go with 8 ohm drivers for the highs and mids. For the low end you can use either a 4 or 8 ohm driver which opens up options for multiple woofers.
