def loudness Posted February 21, 2013 Report Posted February 21, 2013 I want some inputs/advice (LxWxD) to build a 4th order (band pass) enclosure. Utilizing 2- Crystal CMPX2 15's and 1-DD9515g. Limited to space cause I'd like to have my rear seats on my 88 4Runner. Maximum space would be 38.5Wx31Hx35D with my rear seats still available. Now, I'll be running two amps to power the subs...1-OptiDrive 4000d and 1-Audioque 3500d ( 1st version). The Crystal's will be wired .5ohms to the AQ3500 and DD9515 @1ohm to the OptiDrive 4000. Can I seal the three subs in same chamber or I'd have to divide DD from Crystal's? And can they have common port chamber? I don't really want to wall my Runner cause I use it for hunting too, rather have an enclosure that I can take out during hunting season. My calculation on space I mentioned came out to be 21.16cuft. Is that sufficient enough for my 4th order? And would I be able to fit all three subs in that and have a 1 to 3 ratio, as needed for the enclosure.
CJSmith Posted February 21, 2013 Report Posted February 21, 2013 So much fail! SO, here we go... 1.) Do not mix match subs 2.) Off the top of my head, you don't have enough room for 3 15's in a 4th 3.) Do not mix match amps as well. Want my advice? Build a nice ported box (4th order if you have room) for your 9515, and run it on the AQ amp. You'd be more than happy with it, and it's actually practical. *Rebuid in progress*
CJSmith Posted February 21, 2013 Report Posted February 21, 2013 Btw, welcome to the forum. *Rebuid in progress*
def loudness Posted February 21, 2013 Author Report Posted February 21, 2013 I've got the subs...why not use it. My 2cents...
def loudness Posted February 21, 2013 Author Report Posted February 21, 2013 Also, I've got them in one big slot port box now with divided chambers and it's very loud...both tuned @35hz. Why not a 4th order??? Just experimenting a 4th from slot port enclosures...maybe it'll be stupid loud.
CJSmith Posted February 21, 2013 Report Posted February 21, 2013 Maybe someone with a little more knowledge will chime in, but mismatching subs AND amps is a bad idea, PERIOD. I'd stick with the 9515 on the AQ amp in a GOOD ported box. What is your electrical even like? *Rebuid in progress*
def loudness Posted February 21, 2013 Author Report Posted February 21, 2013 3 runs each 0ga +- 55ah agm under hood to 2 XS D7500 with 225HO alternator with 120 amp @ idle. XS is picking up ampere power slack. With the two mono amps and one 4 channel amp for highs...roughly 9k-9.5k watts.
CJSmith Posted February 21, 2013 Report Posted February 21, 2013 Well, I don;t know much about Crystal subwoofers, but from what i've read they seem really good. But like I've said before. Go with 1 or the other. Do the 2 Crystal's or the DD 9515. IMO, I'd run them on the AQ amp, alot better quality than the OPTI. *Rebuid in progress*
def loudness Posted February 21, 2013 Author Report Posted February 21, 2013 And I've already got a ram-designs slotport box@36hz for my DD9515 already, I have ran my opti 4k to it' and now I just picked up thr crystal's and AQ3500 a week ago. And with my current box for the three subs @35hz, DD with ram-design box doesn't even come close to the loudliness and flexing as now. I just want to experiment with a 4th order...if it's gonna be louder.
CJSmith Posted February 21, 2013 Report Posted February 21, 2013 ... I give up. Good luck with your fail. *Rebuid in progress*
