grey15 Posted February 23, 2013 Report Posted February 23, 2013 Hey what's up fellas, I just put my T10004 back in my tacoma and fired it up. With the speakers connected the front channels started clipping, with NO volume. I disconnected all speakers and RCA's and still clipping out of control. The protection mode isn't coming on, and the Rear channels seem to be working. I thought maybe a ground connection issue but the rear channels seem to be working. You guys have any ideas? The amp is not the bdcp. Just the 1st T10004 with the LED lights on the front. thanks for the help T10004 10" AQ HDC3 yep in a prius.. I know, I know why a prius..
Noel989 Posted February 23, 2013 Report Posted February 23, 2013 Where do you see the clipping? If it's from the LEDs lights from the amp neither of them are clipping indicators Build Log - http://www.stevemead...-cruiser-el-pt/
grey15 Posted February 23, 2013 Author Report Posted February 23, 2013 the fronts LED, whatever they do the're bouncing in the red area and a pulsing sound is coming out through the channels. T10004 10" AQ HDC3 yep in a prius.. I know, I know why a prius..
Noel989 Posted February 23, 2013 Report Posted February 23, 2013 Ones voltage and the other one is I think is output not sure on that but I'm sure is not a clipping light cause I've read about it here and is ok to see it go into the red Bur not like your describing Everything was hooked up the same ways as last time? Build Log - http://www.stevemead...-cruiser-el-pt/
grey15 Posted February 23, 2013 Author Report Posted February 23, 2013 Yeah everything's exact.. I'll try and re-ground it, hopefully it's that simple. I'll keep you posted. T10004 10" AQ HDC3 yep in a prius.. I know, I know why a prius..
grey15 Posted February 25, 2013 Author Report Posted February 25, 2013 Well it was a ground issue, thought I would let you know so you don't make the same mistake. Thanks for the help on this one! T10004 10" AQ HDC3 yep in a prius.. I know, I know why a prius..
