Bocks Quackulator
I found a box calculator on subwoofertools, and i was lookin and i came across the box builder.
im not sure what the lingo is even to this day, things like Qes Q Re, etc.
and im not sure about my subs displacement or any of that.
is this a good starting program for someone like me who wants to build a basic (crude) enclosure
Here is a rough diagram and specs of my box
8v fury said:
2 alpine type rs
MAX DIM
38"wide 24" deep by 20"high
EDIT" i have no idea what the xmax is for the subs nor do i know the subs displacement. If anyone could help with that part, id greatly appreciate it
8v fury said:
i know the displacement is .71 and the xmx is just a hair shorter then the rli 8
clarion cz500 head unit
Kinetik hc600
2 level 3 15s in a 4th order
mb quart 1500.1 (for now untill i get a dc 1.2k)
all knu konceptz wiring
in a 2009 ford flex
-DISKOLORED AUDIO-
-Authorized Dealer for DC Soundlab in Alaska-
yeah you have to use the xmax as the factor that changes the port width, it isnt correct and never will be but just use the guidline of 12-16sqin per cuft
per crutchfield:
Recommended Vented Box Volume: The vented box sizes recommended by Alpine range from 0.75 cu/ft to 2.0 cu/ft. Within this range, the ideal size recommended by Alpine is 1.7 cu/ft, so this is the enclosure recommended by Crutchfield. A slot port with the following dimensions should be used with the 1.7 cu/ft enclosure: W=12", H=1.25", L=21". If you cannot use a slot port in your enclosure, you will need a port tube with the following dimensions: Diameter=3", L=9.9".
so:
imo
http://www.subwoofertools.com/forum/ported...mp;Fs=&CE=0
  • Who's Online   0 Members, 0 Anonymous, 1872 Guests (See full list)
