Voltage drop/dimming lights trying to remedy
Hi guys. Been a long time since I posted. Here's my issue. I have a Hifonics brz2100.1D. My alternator is 110 amps. (They don't make H/O alts for my car yet which is a genesis coupe so I'm stuck with it.) I have the Big 3 and replaced my starting wet cell battery with a Kinetik 1200. I chose the 1200 cause it had reverse terminals which worked with my stock wiring. The voltage drop and dimming is a little less then with the wet cell but it's not solved yet. I'm wondering if adding a second 1200 in the trunk will do the trick. I'd be happy with slight dimming but I would like to know if it will be worth it to pull the trigger on another 1200.
Honestly id say it would help a good bit considering its not draining off your primary battery and me personally dont care for capacitors in smaller systems so adding a good extra battery would help your voltage. good luck man im dealing with lights dimming with just my system sony cd player pioneer premier 6.5 in front and rear doors and 2-12 sony gtrs ported box with rf punch 8002 newer style with chrome covers and ive got just 105a alternator lol amp has three 40amp fuses
----------- no more blazer-------------
New ride 2000 s10 ext cab xtreme zq8 v4a
4.3 jba headers,pcm4less tuned,nv3500 5spd,8.5" diff,ported/polished heads
makes good daily driver not a racecar lol
system:
pioneer 7200hd deck,kenwood kfc708 with jl xd400.4
stinger 2gauge wire
mtx thunder 1501d
custom built box myself ported 3.13 slot port 40hz (2) 10" re audio sexv2d2- may do sxx upgrade soon after tune the sex first
kicker 4x6 cs dash.
Sucks to have a stock alt doesn't it. I'm sure another battery would help but I don't want to shell out the money if it doesn't help enough. I think what I'm going to do is hook up my original starting wet cell in the back for a bit (not long enough to damage either battery) and see if that helps at all. If it does at least a little then I'm sure an AGM will be better. Fingers crossed.
having that wet cell if its not already damaged can damage your kinetic. wet cells usually go bad by dying cells. creating resistance and heating up your battery.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
The wet cell is still good and you think it will hurt the kinetik to just try it for a 5 minute drive just to see.
no probly not. but buying another battery is really only gonna help. maybe buy a big boy batt for the back. thatll be night and day difference.. but youll almost nevr get rid of dimming lights unless your voltage doesnt drop below 13.5 ish
I'm gonna try the wet cell out of curiosity for a few minutes and go from there. One thing though isn't it bad to run two different size batteries even if they are the same make. Two 1200's should be enough for 2000 rms no?
Yup big 3 is done with 1/0 gauge and 1/0 gauge amp power/ground wire. Helped a bit. System hits hard as hell and I've had it for a long time and amp still runs fine even though voltage drop but during the winter in the dark hours I just got sick of the dimming. I hate looking like a strob light going down the street. I also too want to keep the batteries as light as possible as it's a sports car.
http://www.youtube.com/watch?v=lqCS1agugtg
  • Who's Online   0 Members, 0 Anonymous, 575 Guests (See full list)
