pontformulalt1 Posted March 10, 2013 Report Posted March 10, 2013 I use these on my main battery under the hood they seem to work ok but it is very important to take your time when inserting the wire at the correct length or they are useless. its also best to build these out of the car if possible. i had to put the term. in a vice to really torq down on it and the compression fittings are very easily bent or crushed if you dont apply even pressure. I went with these terminals because i am running an optima dual post battery. when i change to xs power battery i will be useing soldered ring terminals as i feel it has more contact area to the wire and can be removed and installed much easier. these are not very good quality and i don't feel 100% about the connection that is made as the wire is just folded over and smashed. it also seems very prone to corrosion inside the compression fitting. I DONT recommend these.
