VVX Banana Plugs?
Yup hate them. Cuz I used them and they did indeed vibrate out Nd arced the terminal
Luckily didn't damage the sub.
Probably not enough power :( lol
hahaha which is why I said secure them. I solder mine in on my last set up (before the Skar stuff) and they worked great. Just a small amount to ensure they stay. Easy to remove too. I also taped around them.
10501650_10203332501847103_1859383749711
Blown
With that many drivers I usually use posts and run a separate wire to each driver.
By this you mean, like bolts on the side of the box? And using ring terminals on each bolt to change imp.?
yes
That's what I was kind of thinking about doing. Figured it'd be the easiest.
Fuck banana plugs
lol..thanks for the insight bud.
If you use banana plugs, monoprice.com has some that fight 10 ga easily
These do but they tend to move
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=2943&seq=1&format=2
These also fit and I like them:
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=2945&seq=1&format=2
But as Big-A said, I would do bolts. Run each sub pos to a bolt and each sub neg to a bolt, then use the the bolts to wire for impedance. Much easier, just keep track of which bolt is which lol
Nothing wrong with banana clips if you ensure they will stay in and not vibrate out or move around and hit each other, etc.
....How would you secure them? O.o Don't really want to solder them in the event I ever want to upgrade the woofers and sell these.
Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893
real men dont use fuses :D
Neither do morons
Says the guy with lambo doors on his Ford Taurus.
  • Who's Online   1 Member, 0 Anonymous, 441 Guests (See full list)
