FosgateLife Posted March 11, 2013 Report Posted March 11, 2013 Okay so im redoing some of my wiring and stuff in my trunk and i got to thinking, how am i PROPERLY suppose to power my AudioControl LC2i? Right now what im doing is running it into the power of one of my amps, and then grounding it in a separate place. Is this safe? What is the best way of going about getting power to it? Could i run some wire to the front of my car (inside) where my LED lights distribution post is? (Dual 18 gauge power and ground leads) Or is that not safe either? Im just confused. I guess a question that is relative to this is how to hook up an active crossover? Thanks for the help. Im a noobie. Ahhah 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
mrd6 Posted March 11, 2013 Report Posted March 11, 2013 I dont know the specifics of the audiocontrol you are using but in general, in no particular order: -Hook up positive power to your 12v power source with a properly sized inline fuse -Connect your remote turn on to a switched 12v ignition signal -Make sure you have a solid ground for your negative return ...Pretty much the same as hooking up any amplifier Does that answer your question or? My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
FosgateLife Posted March 11, 2013 Author Report Posted March 11, 2013 Sort of. Im asking where a safe place to hook up the Power lead would be 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
FosgateLife Posted March 11, 2013 Author Report Posted March 11, 2013 Anyone else? 2007 Volvo S40 2.4i (no turbo )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Wicks Posted March 12, 2013 Report Posted March 12, 2013 mrd6 nailed it. Connect it as anything else. Anywhere along your 12v system is fine. As long as the current demands are met (correct wire size) then you're good. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
