new box build not loud?!?
sbg
Am i forgiven though kranny for helping with side issues?? :(
It looks like Ports don't have much breathing room but you said you moved box around?
in a million, trillion, kabillion years,i would never play that song in my ride. I don't care if its clipped or not LOL. I feel like my nads got clipped after playing this for 15 seconds just to see what it was LOL.
No thanks bro. Not into it.
only have moved box to gate and back from gate. after thinking about it i think they may be out of phase. but tomorrow i will check and if thats not it i will move box all around :drink40:
crossovers don't have anything to do with this problem when the woofers are moving an inch a piece playing regular music. have you tried different box orientations for shits and giggles?
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
yes i put the port right on the gate and also moved it like 6" back from it and same thing!
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
keep us posted, probably out of phase if its not louder than an 8, but are you sure its wired down on the amp correctly?
for example, you may think you have it wired at 1 ohm, but accidentally wired it in 4 or something so they may not be getting much power?
Edit: what VVME amp is that, 1200?
cant find any info on those subs, what are they rated at?
Good possibility they are starving for more power
im going to say that they are out of phase not sure but thats what im going for :shrug: they are dvc 2ohm and on my dmm they read 2.3ohm at the amp. i cant find specs to but i think they are 1000-1500 rms each and are for sure lacking in the power side. only runing 600rms to them for now. the amp is a QA-D1500. the subs have 3" coils anda re around 45 lbs i would say, the company is now out of business
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
that would be a huge reason why they wont be loud,
if you only have 600w RMS, on 2 1500w RMS subs, thats the problem man, those subs will have such a stiff suspension, 300w per woofer is not enough to hardy move them, and you have high odds of damaging them from being WAY underpowered
Many 1000w to 1500 w RMS subs on the market will barely perform until they have that 1000 to 1500 watts of power
i say out of phase because i use 10ga wire in box and could not fit it in terminals good and could have mixed them up, dont help that i used all blue wire inside lol
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
check the vid they move alot!
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
i hear u for sure upgraded for amp for sure! and i know this... but still the bass is not what it should be.
think of it this way,
how well will a 6000 horsepower top fuel dragster run with 87 octane fuel
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 1257 Guests (See full list)
