Azzazel_99 Posted March 21, 2013 Report Share Posted March 21, 2013 Im thinking of replacing my l7's since they arent a great match for my amp or i could keep them build a better box and replace the amp with something that will run 1500+ rms at 2ohm. I'm swaying back and forth what which to replace the amp or the subs. Subs are brand new only 2 months'ish old and same with the amp. If i re wired the subs it would run at .5 ohm and i dont think thats a smart idea for a brz2100.1D lol. Advice? Discuss........... Link to comment Share on other sites More sharing options...
bkolfo4 Posted March 21, 2013 Report Share Posted March 21, 2013 That amp is rated 1400 at 2 ohms. Not sure what that amp really does. . . It takes double power in theory to gain 3 dB, but it never happens. So, it will take a lot more power to see big gains. Keep both the amp and subs, build the correct box (you mention building a better box, so I assume yours is less than ideal), and see what you end up with. If you are looking for a night and day difference when you upgrade, better replace both the amp and subs, or really increase your cone area if you keep the same amp. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz. Link to comment Share on other sites More sharing options...
Azzazel_99 Posted March 21, 2013 Author Report Share Posted March 21, 2013 I was thinking of going with something i can run at 1ohm and really use the amps power Link to comment Share on other sites More sharing options...
Azzazel_99 Posted March 21, 2013 Author Report Share Posted March 21, 2013 Since my amp is 1ohm stable its probably gonna be the subs that go first at least thats what im thinking is the right path. The l7's have a nice punch to them but im just not seeing the low low bass but we shall see what i get outta a better box then roll from there i guess Link to comment Share on other sites More sharing options...
