bsipes30 Posted April 3, 2013 Report Posted April 3, 2013 2010 ford fusion hybrid Just highlighting the box build on this one as not much is going into this car. It has the factory nav and premium stereo so i'll use a loc to hook this up. It also has a navigation overide device that i purchased from coastal tech so that we can play movies on the factory screen while driving down the road. After getting this installed i have a bit more information on this. The factory sony amps are on the passenger side and there are 2 of them. one to run the mids and high and one to run the 2 factory subs(they are 6X9 in the rear deck). Once you pull the carpet off the wall you can see the bigger amp and the smaller amp is behind it. Here is the factory sony amp for mids and highs already unbolted Here is the sub amp. It is probably the size of a coke can I placed the line out converter after the sub amp because honestly... how much power is it really putting out? not much more than an aftermarket headunit. Here is what it looks like in the car with everything put back P.S. I got the sub and box for 140 and the amp for 80 bucks... not bad! With wiring and paint and the line out converter i'm around 280 bucks
Gary Hall Posted March 22, 2014 Report Posted March 22, 2014 You may be JUST who I have been looking for! My wife just purchased a 2014 Fusion Titanium Hybrid. She has always had bangin systems. To her disapointment, I was told by Crutchfield that the maximum size amplifier we can add to the car is 350 watts with a max fuse in the amp of 30 amps. Unfortunatly, the highest wattage amplifier I have found with a 30 amp fuse is 250 watts. What is your opinion?
