Cody929 Posted April 8, 2013 Report Posted April 8, 2013 This is what I want to do I had a system in the past and now I just want it to be pretty loud. 2 re audio se-X 15s 0 guage wires (looking still) a box that can fit my trunk it's a 2013 elantra 20x21x42 not that big unfortunately. 32hz my stock headunit unless I can find one that can fit. 2400.1 hifonics or bigger possibly 3000 watts I just need some help figuring it all out.
95legwagon Posted April 9, 2013 Report Posted April 9, 2013 when you say "a box that can fit my trunk" you mean " im gunna build a box in my trunk and tune it to 32 hz " right? and ive heard bad things about certain hifonics amps....so do your research. http://www.autotoys.com/x/home.php?cat=404 look for a dash kit ^ and a decent headunit. higher preout voltage is better. like 4v preouts. heard good things about alpine and a bunch others..... im sure others will chime in. what are you going to do for electrical to support that much power. those elantras only have like a 80 amp alternator........ you WILL need more to support that power. as well as extra 1/0 wire to do the big 3. also make sure you get a decent brand for wire.... alot of brands will claim 1/0 awg wire but you get the equivalent of 4 awg with alot of insulation around it to make it look bigger. good luck i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
SkarredSierra Posted April 9, 2013 Report Posted April 9, 2013 i would suggest knukonceptz for your wiring. a 0 gauge kit on amazon is like 60 bucks for cca. and like 115 for ofc. its great wire. id also recommend a different amp rockford or sundown. maybe even soundqubed? i definately need to replace your stock hu. kenwoods are good. and pioneers too. jvc are ok. plus id get a agm battery to help with the power.
Cody929 Posted April 9, 2013 Author Report Posted April 9, 2013 About how many amps is good for an alternator?
SkarredSierra Posted April 9, 2013 Report Posted April 9, 2013 About how many amps is good for an alternator? that all depends on how much your wanting to push with it and your pricing. first you need to google your vehicle and see how many amps your alternator is putting out now. doing the big 3 in 0 gauge will help alot. you may not need to get a ho alternator if your stock one is putting out enouf. like maybe 100 or over. also look into other stock alternators that may fit your vehicle. some stock alts produce around like 120 amps wich should be enough for some decent wattage with the right battery like a optima yellowtop and a few extra agm power cells.
army_guy137 Posted April 10, 2013 Report Posted April 10, 2013 Here's a dash kit: http://www.amazon.com/Metra-99-7346B-Hyundai-Elantra-In-Dash/dp/B008E6YACQ/ref=sr_1_1?ie=UTF8&qid=1365574528&sr=8-1&keywords=99-7346b Wiring harness 1: http://www.amazon.com/Metra-70-7304-Harness-2010-Up-Vehicles/dp/B004M8RXT2/ref=sr_1_1?s=electronics&ie=UTF8&qid=1365574579&sr=1-1&keywords=70-7304 Wiring harness 2: http://www.amazon.com/Scosche-HY10B-Harnessess-2008-Up-Hyundai/dp/B002G92JY8/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1365574750&sr=1-1-catcorr&keywords=hy10b Not sure which one? Both Scosche and Metra list different plugs? You'll have to check. Antenna: http://www.amazon.com/Scosche-KAAB-Antenna-Adapter-Hyundai/dp/B004H1V976/ref=sr_1_1?s=electronics&ie=UTF8&qid=1365574914&sr=1-1&keywords=kaab If you want the one from autotoys like 95legwagon suggested, it'd be http://www.autotoys.com/x/product.php?productid=26617
