XS Power
From what im reading, the xs chart just points you in the ball park area and I could use the better judgement from you pros. I have a 2008 mitsubishi lancer gts and my group size is 35. I don't know why nobody makes a agm battery in that group size, anyways i looked up the size of a standard group 35 and a d5100r comes the closest. So now that I got that figured out, what do you guys think i should put in the trunk? (If I was to follow the chart another d5100r would be enough but i doubt that.)
The equipment im using:
(1) Rockford Fosgate 3sixty.3
(1) Crescendo BC3500 (Plan on running at 1ohm)
(1) DD 9512i
(1) Rockford Fosgate PBR300x2
(2) Pyle PDBT38 in the rear deck
(1) Rockford Fosgate PBR300x4
(2) Beyma pro6mi
(2) Soundstream TWS.4
(1) Lanzar Opti 500x2 ( Open to suggestions for a 2 channel amp that could put out 500x2 rms @ 4ohms or close to that)
(4) Audiopipe APMB-8 in the rear deck
My alt is factory and its 120a (still looking for a high output alt, what size should i get if i do find 1?)
Factory double din navi unit with 30gb internal
Crescendo bc3500
DD 9512i
