How to stop high freqencies from coming through mids?
FosgateLife
If ur running active u can set high pass at 80hz and low pass at 3500 hz to kill the higher frequency in the midbass
Set the low pass on what?? The amp has either a LP or HP. Not both?
And okay thNks for the advice snow! I will try this! I have the RF T2 comp set crossover btw
Set ur lowpass to 3500 then and on ur HU set ur high pass to 80 or 125hz depending where u want ur mids to start playing
no, if he sets the low pass on the amp, a 2 channel, his highs will never get any signal.
Your crossovers with your t-2's is low pass for the mids, and high pass for the tweets. the crossover does not protect your mids from low frequencies however. So you may want to get bass blockers. I think the crossovers with the t2's is 12db/octave and around 3500 low pass on the mids. So you will still probably hear up to 5k in them a bit
  • Who's Online   0 Members, 0 Anonymous, 1409 Guests (See full list)
