How to stop high freqencies from coming through mids?
FosgateLife
Ive been playin around with the amps and stuff today and i realized that my T2 midbass in the front doors are both producing high frequency sounds that tweets are suppose to be making..Zlike 5k and up.... My questions are:
1. I have a component set so is it suppose to be like this for a reason?
2. Can i stop it in any way?
3. Does it honestly even matter? Btw im running my front door comps off of a 2 channel Coustic Power Logic 360. Thanks!
2007 Volvo S40 2.4i (no turbo :( )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Are you using crossovers? You could try running active, but you may need some new equipment before you can do that.
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
Lol advertisment^^. Lol.
Ye si am using crossovers. So are my ears decieving me? Or does the crossover only work as a HPF on the mid ?
It really depends on the crossover
Unplug your tweeters and play 1k, 3k, 5k, and 10k
If ur running active u can set high pass at 80hz and low pass at 3500 hz to kill the higher frequency in the midbass
Set the low pass on what?? The amp has either a LP or HP. Not both?
And okay thNks for the advice snow! I will try this! I have the RF T2 comp set crossover btw
Set ur lowpass to 3500 then and on ur HU set ur high pass to 80 or 125hz depending where u want ur mids to start playing
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
Dont have aftermarket HU. Its impossible with my waterfall dash. Lol so i. Stuck with one, unless i get a processor
if you're using the passive crossovers then that's simply the way rockford designed them to play, now if you had a headunit like a pioneer DEH-80PRS, 880PRS, or DEX-P99RS you can run active and set the crossover to suit your preferences.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
  • Who's Online   0 Members, 0 Anonymous, 1162 Guests (See full list)
